Topic: Using UFX II to connect MIDI devices to DAW and modular synth
I have a modular synth that at the moment is being controlled by a Novation SL61 MkIII MIDI controller: I have a MIDI cable running from the Novation to the MIDI in on a sequencer in the modular.
The output from the modular runs to my UFX II and from there via USB to a MacBook Pro, where it is recorded by Logic Pro.
I want to set up my DAW (Logic Pro) on my Mac as the master controller of the modular.
One idea I had was to run USB from the Mac to the Novation controller, which would be (as now) connected to the modular via a MIDI cable.
Another idea would be to run a MIDI cable from the MIDI out on the Novation to the MIDI in on the UFX II. And run a MIDI cable from the MIDI out on the UFX II to the MIDI in on the modular. Would that work? Would the MIDI messages flow from the Mac (Logic) through the same USB cable that currently is transmitting only the audio data from the UFX II to the Mac? That is, that USB cable would now be a two-way street instead of one-way.
Is either of these routes better than the other? Is the MIDI out from the UFX II likely to be incompatible in any with what the modular sequencer expects? That is, it's all just one standard „voltage", right? (I haven't really used MIDI that much -- mainly I use CV/Gate).
Is it at all problematic to hook the Novation MIDI out directly to the UFX II MIDI in?
