Topic: Help with MIDI Control for Babyface Pro in Standalone Mode
I’ve been experimenting with MIDI control on my Babyface Pro FS and have encountered an issue with using a MIDI controller in standalone mode.
TL;DR:
I want to use my MIDI controller with the RME Babyface Pro, receive audio input over USB (e.g., from my MacBook), but avoid having to use TotalMix FX—either by running it in the background or ideally not needing it at all.
My Setup:
- Babyface Pro: Functions well with USB playback (e.g., Spotify) and MIDI control when TotalMix FX is open.
- Intech Studio PBF4 MIDI Controller: Successfully sends MIDI signals to TotalMix FX while connected to my MacBook. I can adjust the volume of my Output devices AS 1/2 and ADAT 5/6
- MIDI Routing for Standalone Use:
- The PBF4 connects via USB to my MacBook.
- I use a Roland UM-One MIDI interface to send signals from my MacBook to the Babyface Pro’s 5-pin MIDI DIN input.
- MidiPipe on macOS: Routes MIDI signals from the PBF4 to the Roland UM-One output.
What Works:
1. When TotalMix FX is open, the Babyface Pro responds perfectly to MIDI signals from the PBF4 routed through the UM-One.
2. MIDI activity is visible in MIDI Monitor, and the Roland UM-One’s LEDs confirm MIDI signals are sent.
The Issue:
I want to use my MIDI controller and playback audio without keeping TotalMix FX open as a window all the time.
- Hiding TotalMix FX: Currently, there’s no option to minimize it to the system tray (on Windows or macOS). The window must remain open, which disrupts my workflow.
- Not Using TotalMix FX: Ideally, I’d like the Babyface Pro to respond to MIDI signals in standalone mode based on the most recent TotalMix FX configuration.
- However, it seems the Babyface Pro doesn’t respond to MIDI in standalone mode or might not be saving my latest TotalMix FX configuration correctly.
- Standalone Mode Behavior: When TotalMix FX is closed, I don’t see any response to MIDI signals, even though I’ve verified the MIDI routing.
MIDI Monitor Log when normally connected with Totalmix, trying to use the UM-One to send the midi signals:
17:36:46.698 From Grid Control 1 Channel Volume (coarse) 35
17:36:46.698 To UM-ONE Control 1 Channel Volume (coarse) 35
17:36:46.699 From USB MIDI Device Control 1 Channel Volume (coarse) 35
Questions:
1. Should the Babyface Pro retain the latest TotalMix FX configuration in standalone mode? If so, how can I ensure that the configuration (routing) is properly saved to the device?
2. Are there known limitations with the Babyface Pro responding to MIDI signals in standalone mode? (except for not being able to adjust advanced settings like EQ etc)
3. As an alternative, is there a way to hide TotalMix FX to the system tray so it doesn’t disrupt my workspace while staying active for MIDI control?
Any advice or tips on how to achieve a streamlined setup without keeping TotalMix FX as an open window would be greatly appreciated!
Thanks in advance!
