Topic: UCX interface shows up as separate pairs of IO in Ableton Settings
When I go to select the interface from the audio preferences in Ableton, each pair of IO shows up as its own interface for both inputs and outputs. There was another thread where someone had the same problem but didn’t say how they fixed it. Anyone know? I’m on PC Windows 11.
Re: UCX interface shows up as separate pairs of IO in Ableton Settings
I do not have Ableton, so cannot try. But are you using ASIO driver for UCX in Ableton? Aren't you using WDM? In that case inputs and outputs might show as stereo pairs.
Class compliment mode?
