Topic: UCX II vs UFX III
Hi there,
in January we'll be equipping a new research space with a multi-channel interface, it should have a flawless Linux experience. I had been eyeing the UCX II for this, but of course the question is now whether we should go for the UFX III. As a public body (university), we are keen on rational and economic arguments, so the price difference is important. We also have a good A&H analogue mixer, so number of Mic Pres is not too important. We need to be able to run 8 analogue in / 8 analogue out for the time being, and one ADAT is sufficient. Here is my pro/cons for UCX vs UFX:
pro UCX
- smaller form factor, makes it easy as a mobile device as well (this will be one scenario, carrying it around to field work)
- in the same scenario, being able to use it as a battery powered field recorder
- half the price, no waste on MADI that won't be used in this studio in the next decade
- a little longer on the market, potentially less issues, oscmix compatibility on Linux
pro UFX
- not a horrible Y-splitting-cable solution to get eight analogue outputs; leaving HP usable separately
- DURec port on the front panel instead of back panel
- built-in power supply, not the horrible extra DC adapter
- no need to buy additional rack mount
Any thoughts (*with respect to Linux scenario*)?
