Topic: ADI-2 Pro & 2/4 - Help!
Hello There,
I am trying to decide which unit would be best for my needs. Between the Black Edition and Special Edition ADI-2 Pro.
Okay, here is my use case. I am a Music Producer/Musician and would like to use it for the purpose of Production, mixing and mastering. Mainly for much better conversion and headphone amp, than my current interface 'Apollo Twin'. I carryout a lot of my work on headphones. I also use the Audient Nero monitor controller in my setup.
Currently my monitors:- Neumann Kh80's, NS10's are both connected to the Audient Nero via outputs and then the Apollo Twin is connected to SRC1 input of the Audient Nero.
I would like to know if I were to connect the ADI-2 Pro to the SRC2 input of the Audient Nero, would this compromise the quality of the conversion?
If this will not be the case then I would go ahead with the Black Edition, which offers great savings over that of the 2/4! My only reason for going with the 2/4 would be if the conversion quality would suffer using the Nero and therefore I would indeed require the additional two outputs of the 2/4 to connect both sets of monitors (Kh80's and NS10's).
Any help or advice anyone could provide I would greatly appreciate it.
Thanks in advance.
