Babaluma wrote:KaiS wrote:ADI-2’s EQ works great for room correction.
What you need is a measurement tool for room acoustics.
I suggest FFT from Andrew Smith, out of the Audio Tools suite, for iDevice.
https://apps.apple.com/de/app/fft/id298840058
For just 12 bucks it turns an iDevice into a calibrated, full fledged measurement system.
I have the ADI Pro 2/4 and have been wondering what the best way to measure my room was recently. I'd love to see you write clear instructions for how to measure with this FFT app, if you ever have the time @KaiS
Is it as easy as sending pink noise through your monitors, placing the iPhone with this app in the listening position, saving the resulting FFT graph, then applying a smoothed "reverse" EQ curve to your monitoring with the RME EQ?
Look here for a basic measurement instruction, in the context of subwoofer integration:
https://forum.rme-audio.de/viewtopic.ph … 12#p155312
To do a measurement needs to define a goal in the first place:
• Linearizing a full range speaker is done in the nearfield of the speaker, 50-100 cm distance on listening axis, equidistant between tweeter and midrange driver, to exclude wall/room reflections.
• Improving the room response only works in the low frequency range, up to ca. 250 Hz.
This is done with the measurement mic at the listening position.
• Same for integration of a sub.
Why is that:
A measurement mic does NOT differentiate between direct and wall reflected sounds.
The human auditorial system DOES, the direct sound from the speaker largely dominates the reception, room sounds are kind of “excluded” subjectively.
Only at low frequencies this mechanism’s efficiency is reduced.
In typical domestic rooms the direct/reflected ration reaches 50:50% (the “reverberation radius”) at a distance of 50-100 cm from the source.
To mostly look at the source, not the room, you have to measure that close to a speaker.
• Typical settings for FFT app:
(Not mentioned parameters should stay at default)
FFT Settings (wrench symbol):
FFT Size: Equal Points / Octave EPPO
dB Range for 1 dB Scale: 30 dB
Advanced:FFT Settings: Blackman: Overlap 90%
Graph settings:
Graph Smoothing 1/3 Octave
Graph Decay 8s Decay, or Average (for precise results an 20-30s run can be averaged, needs a restart for each run)
