101 (edited by rawac 2024-07-26 12:19:57)
Re: ADI-2 Remote V 2.0 – we can't stop!
Arie1111 wrote:
Been enjoying my ADI 2 FS for about 3 years now. .... Couldn't live without the PEQ functionality ... using the remote software to backup my settings. ...
This is an ADI-2 FS:
https://www.rme-usa.com/files/uploads/RME-Products/Converter/ADI-2-FS-C.png
No USB, no remote software, no PEQ. sad
For an ADI-2 PRO or ADI-2 DAC or ADI-2/4 PRO you can connect a unidirectionaler USB A to SPDIF adapter to your PC and use the ADI-? *** SPDIF input as second input.
Ralf
(ADI-2 Pro FS with ThinkPad Yoga L13, Dynaudio Focus 600 XD or Focal Clear — and a lot of Jazz)
Ah... Though the front of my DAC only says 'ADI 2 FS' tt appears I have the ADI 2 FS pro version, with the built-in display, USB input and  and PEQ capabilities.
Arie1111 wrote:
Been enjoying my ADI 2 FS for about 3 years now. It's just awesome. Couldn't live without the PEQ functionality any more to get the best out of my speaker and headphone setups. Since I put a lot of energy in getting the PEQ profiles right I love the idea of using the remote software to backup my settings.
Now my question. I stream music via the usb input. The FS has only one input. Is there any way I can connect the streamer and a windows PC at the same time? E.g., using a hub?
1) ADI-2 FS has no EQ functionality.
2) ADI-2 FS has two digital inputs (optical and coaxial) and an analog input.
3) ADI-2 FS has no USB interface.
4) USB hub generally does not allow connecting more than one host device. If you need to connect USB devices to more than one host, you need to use a USB switch with more than one upstream ports or a USB-over-IP switch.
104
We never sold Pros that have no 'Pro' printed on the front. Could you provide a photo for clarity?
Mine looks exactly like this:
https://cdn.webshopapp.com/shops/345009 … dac-fs.jpg
Sorry for providing a link - uploading a picture is not as straightforward as I thought.
106
https://cdn.webshopapp.com/shops/345009/files/425193958/rme-adi-2-dac-fs.jpg
Use [img]...[/img] instead of [url]...[/url].
DAC
roll
Ralf
Ah, you're right - the word DAC is in between.
Back to the original Q: it's clear to me now that I would need a USB switch. Which is a pity because it means I can't make changes on the fly via the PC and immediately assess what it does sonically. (The streaming device loses connection and needs to reboot to reestablish the link with the DAC).
The software will serve me well to make backups of my PEQ profiles though. Thanks for that RME!
108 (edited by ramses 2024-07-27 12:35:28)
Arie1111 wrote:
Been enjoying my ADI-2 (EDIT: DAC) FS for about 3 years now. It's just awesome. Couldn't live without the PEQ functionality anymore to get the best out of my speaker and headphone setups. Since I put a lot of energy in getting the PEQ profiles right, I love the idea of using the remote software to back up my settings.
Now my question. I stream music via the USB input. The FS has only one input. Is there any way I can connect the streamer and a Windows PC at the same time? E.g., using a hub?
Which streamer? Does it have - besides USB - other digital outputs like optical or coax. SPDIF?
Then you could connect it this way:
Option A:
PC---USB---------------ADI-2 DAC FS
Streamer---SPDIF---+
Option B:
More flexibility might give you such a setup with RME recording interface and TotalMix FX:
    +--USB---ARC USB (optional: remote controlling TM FX of Digiface USB)
PC---USB---------------------Digiface USB---ADAT OUT------->ADI-2 DAC FS
                                          ADAT IN
Streamer---SPDIF(opt)--+
More Options:
If you like a PCIe card more, then instead of Digiface USB (€444) or a PCIe based card. This you could combine with an ARC USB if you want to change the routing based on the Digiface USB (TotalMix FX) by pushing a knob.
109 (edited by KaiS 2024-07-27 12:50:10)
Arie1111 wrote:
…  it means I can't make changes on the fly via the PC and immediately assess what it does sonically. (The streaming device loses connection and needs to reboot to reestablish the link with the DAC).
If your streamer doesn’t have Optical or Coax out, get an inexpensive USB to Optical (preferred) or Coax interface, between streamer and ADI-2 DAC.
This way you can have PC and streamer both connected AND active at the same time.
Even better than an USB switch that might cause more problems than it solves.
110
Would you guys consider open sourcing the remote? It sure would be great to have community support. If not, what about adding api access or midi mapping so we can extend the use cases to hardware? So many great modular encoder and pot systems out there that would be perfect smile
The MIDI command reference was published simultaneously with the ADI-2 Remote app.
Will this be available for Android?
113 (edited by hpw 2024-09-21 09:34:11)
On ADI-Pro & Fs gear, I did some FW driver & FW updates & Remote V2.1.
On ADI-2 Pro & Remote V2.1.: Captions show "no connection" as SR gets false/NOK as 48kHz.. On Driver as 44.1kHz OK, on Gear as INT 44.1kHz  OK.
114
https://forum.rme-audio.de/viewtopic.ph … 06#p215306
Well,
checked before Win10 boot, as midi was already ON.
Surprise, it worked now big_smile
116
I love my 2018 ADI-2 DAC so much I'm getting another one - an ADI-2 Pro
Reasonings aside I was wondering how well the windows remote program reacts to having two ADI-2 devices plugged in. Can I control both from here or only 1? Maybe some sort of drop down window?
I guess as well, other than just switching output in windows, how good or bad of an idea this is in the first place.
I am wanting to use the analog inputs of the Pro, and the DAC of the DAC edition. Probably will switch to just using the Pro but wondering how using both will be. Nothing complex like trying to route audio out to both at the same time or anything, just above trying to control them via software with both plugged in and active at the same time.
Searched the forums and only found questions regarding using the physical remote control with two devices
117
You can control both, each has its own window. If windows were closed use Options - Show all connected to get all windows back without restarting the app.
You did not find something in the forum because it just works...
Hi Matthias,
I have a „special“ feature request for ADI-2 remote app. As a proud owner of ADI-2 pro fs, I would like to remotely control it wirelessly via iPad by means of connecting the product CME WIDI Uhost to the USB port. MIDI Ccmmunication between iPad and ADI-2 works fine, as long as I am sending MIDI Sysex commands to the unit by third party MIDI software and receive appropriate messages from the ADI-2. However, it seems that the ADI-2 remote app does send commands and receive messages only via USB cable connection. Would it be possible to „route“ commands sent by the app also via Bluetooth port and receive response messages via the Bluetooth port? Thank you for negociation!
119 (edited by Brain64cores 2024-10-08 16:15:10)
Hello.
I have a question, that I can not find an answer to anywhere.
Can I control maximum loudness allowed to avoid sudden very loud sounds in my games, like gunfire. I want to hear steps so I max my volume and then sudden very loud shooting happens and my ears are bleeding.
I use Sennheiser HD800S and here is my PEQ settings:
https://imgur.com/l66zKNe
120
That would equal a limiter or compressor effect - and is not available.
121 (edited by vB 2024-10-22 18:47:27)
Another feature request for the remote app and possibly the hardware (ADI-2 Pro FS): Cycle through user defined outputs and/or buttons to select outputs exclusively.
I use the ADI as monitor controller and have a pair of monitors connected to Analog 1/2, another pair to SPDIF and headphones to Phones 3/4. The basic functionality is there, using Line/Digi toggle and mute vs 3/4. But I’d love to leave the headphones connected plus it’s a little „confusing“, or let’s say inelegant. I’d love some buttons where it’s clear at a glance what is selected and everything else is muted. Plus I’d love an indication in the display that Digi is selected. Now it just says „1/2 off“. Would be cool if it would switch to „Digi“ and still show a volume readout (like in the app). Icing on the cake: A press on the rotary button would not only toggle between two outputs, but cylcle through Ana, Digi, P3/4, repeat…
122
vB wrote:
… A press on the rotary button would not only toggle between two outputs, but cylcle through Ana, Digi, P3/4, repeat…
You can store and use a “Setup” for each configuration.
If you enable or disable “ Load Volume with Setup”, to you get what you want.
Read manual page 29 (DAC), 30 (Pro) or 29 (2/4 Pro SE).
Loading certain “Setups” can be assigned to a button’s push on the device or IR Remote.
Read manual page 26 (DAC), 28 (Pro) or 30 (2/4 Pro SE).
Watch out:
The  “Remap key” configuration is part of each individual “Setup” and needs to be set for each individual “Setup”.
This can be used to toggle through 2 or more Setups with one single button.
Works like this:
As the button assignment isn’t global, but part of each “Setup”, you can even have different assignments to the same button in each Setup - a nice feature that we can use for the following:
Choose ONE single button that you usually don’t need.
In Setup 1 assign: “load Setup 2”
In Setup 2 assign: “load Setup 1”
Now this single button toggles between both Setups.
This method can be extended to load even more Setups if needed, like:
In Setup 2 assign: “load Setup 3”
In Setup 3 assign: “load Setup 4”
In Setup 4 assign: “load Setup 1”
Now the single button circles through Setup 1-4, clever, isn’t it?!
As for loading Setups ADI-2 asks for confirmation, a double-push is needed to execute the load.
Holding the button more than 1s, the button‘s original function is available.
Therefore I typically assign the SETUP button to load Setups – sic!
I own a DAC-2 pro fs be. Newest Firmware and AD-2 Remote for Windows
I don´t find a solution in "EQ Preset Editor" for using the "Listen" function to route the settings to Line Out, not to PH34..
Thank You in advance....
124
You’re right, that IS clever, thanks for the valuable input! Will definitely check it out.
Still, I like the remote app a lot (and usually don’t use the hardware remote), so I guess I am asking at least for some user definable buttons in the app. Those could simply load setups and be renamed appropriately. I mean the setups are there already, but the buttons should be accessible from every tab (maybe in a sidebar?).
However, my favorite would be a „direct“ choice of an output like I described above, without the need to store setups.
Is there any trick to install this great app not only on ipad but also on iphone?
Adi-2 Pro, Adi-2 Dac Fs
126
No
What is the technical reason therefore?
128
iPhone and iPad have different hardware, installation of apps have to go via Appstore.
Wondering if there are plans for the iPad adi app to have network access to the adi that’s connected to a Mac? Just like the Totalmix iPad app.
Happy new year to all.
__________________________
Paul Najar
Jaminajar Music Production
www.jaminajar.com
130 (edited by Luvchampagne 2025-01-11 22:13:11)
https://www.facebook.com/marketplace/it … tid=wwXIfr
Not promoting the item. Just a photo of the display I'm referring to. Active Parametric with LR volume below.
I have an Adi2 DAC FS. Loving the loudness control.
Stupid question. Where in the software do I control the display to show the pretty bar graphs? I can get the small horizontal LR channel below the Volume /Balance  Line Out screen.
I can also toggle to EQ and see the Line Out and the curve it is using.
But cannot find where I can toggle this to a full screen showing the active Parametric analyzer.
I figured it out.
For some reason the volume screen button on Device Mode was not working.
I factory reset and then tried it. Got my cool meters.
132 (edited by DYSTmusic 2025-02-02 23:22:27)
I have the ADI 2/4 Pro SE and was looking for a way to access all the controls and forgot that ADI-2 remote was available
So, a few minutes ago I downloaded and installed it - version 2.1(1)
However, as soon as I opened it, I noticed that it was reading a sample rate of 44.1 rather than the 48 I had it set to previously
OK, no big deal, I went into my Mac's Audio MIDI Setup and set it back to 48
But, as soon as I switched from 44.1 to 48, there was a hiss coming out of the monitors (Dynaudio Core 59)
I switched back to 44.1 and total silence - I tried 92, hiss, and so on
I then uninstalled the ADI-2 Remote app and switched back to 48 in Audio MIDI Setup and total silence
Anyone else experience this? Why would the ADI-2 Remote cause hiss for all sample rates except 44.1?
Thank you
133 (edited by KaiS 2025-02-03 07:17:23)
DYSTmusic wrote:
… ADI-2 remote was available
… I downloaded and installed it - version 2.1(1)
Do you have the latest ADI-2/4 Pro SE firmware installed?
What number is showing at ADI-2/4’s power up?
134 (edited by DYSTmusic Yesterday 00:12:23)
It says v.40
Here is what it says when I opened the Firmware update tool (I noticed the latest firmware update was released on Jan. 29. 2025 and I never installed that so, how can it show that it was installed?)
https://i.imgur.com/iUoOj8r.jpeg
