DYSTmusic wrote:It's incredible to me that people can listen at -6dB (but, this is based upon the experience I posted above that -40dB is loud)
Dynaudio Monitors always had been the choice of people producing heavy metal.
DYSTmusic wrote:I could order an SPL meter from Amazon (probably more accurate than the iPhone internal mic)
I can’t comment on any el-cheapo meter other that it’s not trustworthy.
I’m using AudioTools on various iDevices by myself, have professional Sound Level calibrators (accurate to 1/10 dB) and Bruel&Kjaer Sould Level Meters.
On all my iDevices AudioTools supplied calibration is accurate within +/-1 dB, that’s very good for acoustic measurements.
As mentioned, the Dynaudio app is relabeled from AudioTools.
It’s free, so it’s limited to dBA weighted measurements (low frequencies filtered out), but that’s OK, as low f’s spoil the result due to room modes.
Still, I withdraw my recommendation, as on various iDevices I could not switch on it‘s Pink Noise generator, making usage too complicated.
Instead I suggest to I suggest FFT from Andrew Smith, out of the Audio Tools suite, for iDevice.
https://apps.apple.com/de/app/fft/id298840058
For just 12 bucks it turns an iDevice into a calibrated, full fledged measurement system, and has Signal Generator and Sound Level Meter built in.
What you need is the Apple CCK - Camera Connection Kit to connect the iDevice to ADI-2, or just an USB-C to USB-B cable if you have an USB-C equipped iPad.
You can install FFT on multiple iDevices, use one as stationary generator, iDevice digitally connected to ADI-2, and the 2nd as meter/analyzer.
Or, just record some minutes of SMPTE Pink Noise on your DAW from the iDevice digitally connected (using the Apple CCK - Camera Connection Kit or fitting cable).
• On FFT set:
- Settings / General / Global Audio Settings: Use SMPTE Pink Noise (might be default)
- Start FFT, Wrench Tool, set “A-Wtd SPL”
- FFT-main screen, ~ -sign (Generator): 0 dBFS, Pink, On.
• Play the Noise with all computer volume controls set to 0 dB if you are using a DAW (to achieve a defined reference Level).
• Set ADI-2’s Volume to -6 dB, this is Dynaudio’s reference, so we meet it.
• Send the Pink Noise to one speaker only, from 3 meter distance, that again Dynaudio’s reference.
• On the FFT screen, press the Play-sign to start the measurement.
The top right figure shows the SPL.
Add 22 dB correction factor to the reading.
We need the correction, because we use Pink Noise, not steady state sine waves for the measurement (which are not usable for a in-room measurement).
The result should reflect Dynaudio’s SPL-switch settings, e.g. 88 dB in the lowest setting.
So, you should read 66 dB on the FFT screen figure up right, add 22 dB = 88 dB.
DYSTmusic wrote: Since I am using AES, wouldn't the measurement be -6dBFS, and not -6dB? Would that change things?
That’s the same if you use a full scale 0 dBFS signal as reference, like I did for my prescription above.
This is where the 22 dB correction factor comes from:
SMPTE Pink Noise, RMS A-weighted, relative to a full scale 1 kHz sine wave is -22 dB in level.
