Topic: Mac Digicheck NG 0.91 Setup issue
Hi there,
RME newbie here so please excuse me if I'm missing the seemingly obvious^^
I'm using a Madiface Pro interface (Firmware v69, Driver v4.17) on Apple MBP M1 Pro chip running Monterey v12.7.6.
I have the Analog 1/2 assigned to the main outs in TotalMix plugged into my active monitors.
When I active the Loopback function on on the Main Section I get signal coming in Digicheck - no problem there.
But I don't want it to analyze my monitor outputs - because it's for my monitors (duh!), the levels are usually low and constantly changing - I want it to analyze my Software playback stereo outputs setup at constant nominal 0.00dB.
I wish I could change which outputs Digicheck analyzes, but I can't select any other source in Audio Device Setup.
How can I achieve this?
Thanks for your help
