Topic: BSOD DIGICHECK 5.1/ HDSPe AES
I'm a new RME user. Bought the HDSPe AES instead of LynxAES.
After installing Digicheck 5.1 yesterday, I checked if everything worked properly and it did.
Today, after startup..... opening wavelab, playing a track..... opening digicheck I got audio input, then I switched a couple times between wavelab, digicheck and suddenly there was no audio input in digicheck. And then after a minute or so BSOD.
After restart, I checked if the problem is still remaining, and yes.........again no audio input in digicheck and after a minute or so BSOD.
I pretty much isolated the problem, and it must be related to Digicheck software. For now it seems that Totalmix works properly, as it should.
Already tried rolling back to Digicheck 4.53 but that didn't work.
Anyone experienced the same behaviour, I'd like a solution?
Thanks a lot
Will J
(asus pt6t de luxe v2 mainboard, intel i7 CPU 920 2.67GHZ, RME HDSPe AES, UAD2 duo)
