Topic: HDSPe ExpressCard(34) and Multiface on Lenovo Notebooks
I have the following problem:
I wanted to install an old Multiface box on my new Lenovo X200 notebook Windows
XP 32 bit with SP3, using theHSDPe ExpressCard adapter.
Unfortunately, the installation did not work propperly and there seems to be a hardware incompatibility.
Here is what I did in detail:
According to the manual, I switched off the notebook, plugged in the HDSPe card and
switched the notebook on again. Windows booted and I logged on. In the next step, the new
hardware should have been detected. This did not happen. In order to nevertheless install the driver,
I unplugged and replugged the HDSPe ExpressCard and after I did this, the hardware was found.
I installed the latest driver from the web site and was asked to reboot, which I did.
After reboot, when booting Windows, I got a bluescreen after two or three seconds of boot time.
In the next attempt to boot, Windows was started in the normal mode (not the safe mode) and
the system came up without bluescreen. The HDSP mixer and the setting items are there on the desktop
launching the applications by clicking does not work. Also, when connecting the
Multiface box to the HDSPe express card, the Multiface continuously reports a host error (the
red LED on the Multiface front). Whenever booting the notebook with the HDSPe card connected,
I can reproduce the bluescreen, and the bluescreen does not appear in the second attempt to boot.
I suspect that the driver which seems to be installed, is not operating propperly.
I did the installation procedure multiple times and also on a Lenovo T500 notebook and with a second
HDSPe express card with always the same result and a lot of bluescreens. So, the HDSPe card is not generally broken,
and since other express cards (to enable e.g. Firewire) work well on the Lenovo notebook, I am pretty sure that the notebook
express card slot works.
So here is my question: Has anyone got the HDSPe card running on a Lenovo notebook?
Anybody got an idea what I did wrong during the installation?
If there is experience with an incompatibility of the HDSPe card with different notebook chipsets,
which notebook would this device work on?
Thank you for any assistance and best regards,
Hauke
