Topic: madi loop connection issues
hi RME,
Sometimes i record with mics, but most of the time its samples manipulation.
ive been recording with the micstasy a lot , but i still have not connected the madi.
the reason is i don't know how to do it properly.
In a madi loop with madicard->648->micstasy 48khz/24bit->return to madi card...and 64 channels already going into the 648 from other 9652 places, i am at the limits and i am confused.
Currently i have the micstacy routed to an unused input on one of the 9652, and i use totalmix to route the audio into the madi system. If i connect the micstasy to the adat in the 648 im going to knock out 1/2 of the samplers 16 channels... so i want to use the madi conxn.
I know the micstasy has to be powered on to pass the madi signal thru it, and in doing so will take up 8 channels at this resolution, once again knocking out 1/2 of the samplers 16 channels.
Is there a way that i can make the micstasy invisible? Such that it does utilise up 8 madi chan? And allows only the 64 already used channels thruput? Then when its time to get the mics out, because the samplers have been bounced down, turn those 8 channels on?
I wonder if the matrix router in 648 is going to be any help to me? But i cant see the solution.
Personally, my news is there is a lot to do with music composition, promotion, computer technician, marketing, mixing, mastering....endless list. I am very busy.
best regards to all
johann.
