Topic: Digico and ADI 648 Word Clock Problem using MADI
Hi there,
actually we are recording the actual PUR Tour and we have a fairly intresting issue.
The recording setup on the analogue mobile is Digico MADI to MADI ADI648 electrical in, filter out the controller singnal on channel 57 and then send the MADI signal via lightpipe to the truck using three SSL Alphalinks to convert into analog signals.
The Digico desk used by the production sends a master clock at 48006 sometimes changing to 48007 Hz.
In undefinable time steps an error occures, hearable as a resysnc over all 56 channels.
Now we took the word clock from the desk as clock master not anymore the MADI implemented clock. That reduces the failure and speeds up the resync but until now we were not able to get the issue handled stable. The Alphalinks do not provide an SRC. Is there any unit i can use to stabilize the clock to 48000 lika a SRC for MADI without crashing the sync risking jitter or digital clicks?
I would be happy to get any solution proposals.
All the best
Ulf
