Topic: Hammerfall HDSP 9632 Recording Line-In (volume too low)
the company I am working for has recently bought a HDSP 9632. We want to use it to stream sound, captured
on the Line-In, over a multicast channel to an array of Set-Top-Boxes...
arecord -Dplughw:0,0 -f S16_LE -r44100 | cvlc -vvvv file:///dev/stdin --sout '#transcode{acodec=mpga,ab=128,channels=2}:duplicate{dst=std{access=udp,mux=ts,dst=239.7.7.7:6970}}'
is doing the job perfectly (Strangely VLC 1.0.3 cannot handle this device (alsa init problem) directly therefore
arecord).
Our problem is that the sound recorded this way has a very low volume. The Line-In on the sound card is fed
by the output of a satellite receiver. We are using CentOS 5.4 x86_64 and ALSA 1.0.17
Even with Input Level set to -10 dBV using hdspconf, the volume of the registered sound is pretty low.
We would like to know if there is a way to correct that.
Thank you in advance!
Helmut
www.deuromedia.com
Re: Hammerfall HDSP 9632 Recording Line-In (volume too low)
What is the level of your source material?  Also, have you tried recording anything besides the satellite receiver?  What kind of levels do you see coming into hdspmixer?
