Topic: Fireface 800 + win7 help needed
Hi.
I just recently built a new machine which I'v now done every secound year for the last 12 years. The new ones a 7i 920 cpu, 12 GB ram, 750 watts coisar power, ATI radeon sapphire PCI expresscard and win7 64bit.
I built the machine home and I used a M-audio 1814 firewire card in the included  VIA firewire slot.
I was amazed by the power and stability. I managed:
80 tracks
480 plugins ( waves ssl EQ and Sonnox comp)
64 buffersize
80 percent stabel cpu meter in Nuendo 4 with no glitching or crackling what so ever.
I took the machine to my studio where I installed FF800 with the newest driver and used the same Firewire slot.
On some projects I'm not able to even play 40 tracks without any plugs in 64 buffersize on other songs I manage to run 10 - 20 plugs in 128 buffersize but the CPU meter jumps iradically up and down from 30 to 100 percent and I get the so much hated crackles.  On other songs it opens at 100 percent, but as soon as I hit play it falls down to 30 percent but takes jumps up to 60.
This gets me thinking. The only thing that is different is the soundcard. I have always been a strong believer in RME and it's drivers, but now I get confused. I teach about 60 students each week and they are coming to my studio and I need to get this thing running like Forrest Gump as soon as possible after Christmas Holidays.
I also have 3 records to do in the next 2 months...
I have the latest drivers for everything.
I have tried with a different Iee card. (NEC)
I have taken out the UAD-1's and the POC.
There are no IDE disks in my machine.
Everything is installed clean.
Shall I try a firewire 800 Texas Instrument PCI card? If so, what?
Please, help me put here.
Best regards
Bluemusic
Re: Fireface 800 + win7 help needed
Anyone?
Hi guys.
Could anyone from RME answer this?
I gained a small enhancement by changing the firewiredriver to the win legacy driver, but still much more unstable than M-audio. Could RME- Support  please help me out?
Try changing your Firewire card.
I'd personally recommend the Dawicontrol DC-FW800 PCI Express card (2x 1394b + 1x 1394a) as it solved all my problems and has been rock solid (Win 7 x64, i7)
Finally some answers. Thanks:-)
Is this the card?
http://www.comtech.no/PartDetail.aspx?q=p:2581742;pl:1
Texas instrument?
What was fixed for you with this card?
Is the VIA a Firewire 400 or 800 port?
Is the M-Audio a Firewire 400 or 800 device?
Did you try to use a FW800->FW400 cable for the Fireface 800?
Did you try to run the Fireface 800 behind the M-Audio (using the M-Audio as repeater/hub for the Fireface)?
It is a FW400 port.
M-audio is a FW400 device
Haven't tried 800 usage with my fireface 800 yet since I don't have a proper card. Is the the card mentioned the best card?
