Topic: problem hdsp 9632 projects 88kh sound,and projects 44kh not sound
hello I installed 9632 seems to work, but projects a 44 khz sound not hearing him, in the sequencer works but no sound comes out, projects to 88 kHz if it rings, I open one at 88 and sounds, I close I open one to 44 and not sound, the card I have not touched anything this all by default, thanks
Re: problem hdsp 9632 projects 88kh sound,and projects 44kh not sound
the drivers are 2.94 in windows xp,
More details, please. Are you using the analog outputs?
With 2.94, assignment of analog channels will change between 44 and 88.
Try the new 3.083, this keeps the analog channels in place.
yes using the analog outpouts for monitoring,assignment of analog channels cahnge in the project,change in the sequencer outputs but still not sound,
is this driver for xp? uninstall everything and install this right? thanks
WDM Streaming Treiber f?r das komplette Hammerfall DSP System. WDM, WDM-KS, GSIF und ASIO f?r HDSP und HDSPe Serie.
    Version 3.082 vom 20.10.2009     hdsp_wdm_3082.zip
hello send an email to them days ago
