Topic: ADAT sync problems on HDSP9652 and Cubase 5.1.0
I am having problems with receiving start and stop signals over ADAT sync. running Cubase 5 as slave using the HDSP5692 card. The transport immediately starts running, and never stops even if the stop button is hit on the master system. Sync information is however detected if the jog wheel on the master system is moved, and the transport locator is correctly synced in the slave system. The start and stop signals are however never received, so the transport runs forever in the slave system.
This problem only appears in Cubase 5, Cubase SX 3 is running fine.
Any one knows a solution for this?
The setup:
Motherboard:    P4s800-mx
CPU:        Intel 2.6 GHz
RAM:        2Gb
OS:        Windows XP SP2
HDSP9652:    Fut 108
Driver:        wdm 3.0.82
ADAT 1:        In sync
ADAT sync:    In sync
Cubase 5.1.0:    Slave
PARIS 3.0:    Master
BR
Arne-J. Auberg
Re: ADAT sync problems on HDSP9652 and Cubase 5.1.0
We think we fixed this effect. Please try driver 3.083:
https://archiv.rme-audio.de/download/hdsp_wdm_3083.zip
Great!
I had Cubase look into this as well, and they too will provide a fix for this in 5.5. But maybe you are first!
