Topic: Midi latency with Hardware Synths - Screenshot
I have been having this problem for a long time and it is pretty annoying.
When I export my softsynth midi recordings everything is fine with the timing.
However, I also use hardware synthesizers like Yamaha Motif ES8.
When I record a midi track everything is in time.
But when I create an audio track to record the actual audio of my Motif while midi playback the audio is recorded slightly later. I mean 4ms but it is audible.
Here I have a screenshot of a snare recorded in a midi track, then played back and recorded to an audio track at the same time.
See the difference in the beginning of the note.
http://i237.photobucket.com/albums/ff11 … tency2.jpg
I tried to change the latency of my Multiface II but that did not change a thing. Even if I set it to 2048 buffers or 64 buffers the latency from my hardware synth is the same. Also tried the timestamp options but to no avail.
My setup:
Multiface II 3.083 PCI Express
Windows XP32
Gigabyte EX58-UD5
i7920 CPU
4Gb RAM
7200 RPM internal SATA II hard drive
Thank you for any help. I have seen this problem before reported by users but unfortunately I cannot find the links to these pages.
