Topic: FF400 midi indicator flashing continuously
This is probably a problem with the midi keyboard I just hooked up to the FF400 midi in (evolution MK249), but I can't find the solution.
The Midi indicator on the front panel of the FF400 is flashing continuously - as though receiving CC data - but nothing shows up when tested with a Midi Monitor application.
Tried it on both midi inputs, same result.  Other devices don't have this effect, so am assuming it is the keyboard.
Mostly want to make sure this doesn't represent a potential problem that could damage the FF400.
Thanks in advance,
Chris
Re: FF400 midi indicator flashing continuously
active sense?
Most likely... I get the same behaviour with my Yamaha midi keyboard.
https://granurise.com
Yes it is active sense after all...amazing, I had never heard of it - am still a newb after all these years....:-)
