1 (edited by staki 2010-05-07 06:19:50)
Topic: HDSP 9632 clock
Hello, I just would like to know if the PCI HDSP 9632 card can work with a 24.576 MHz clock instead of a 25 MHz ? I had a physical crash and have to change the clock, but I only have a 24.576 MHz, that's the reason I ask for.....
Thanks for the answer !
staki
Re: HDSP 9632 clock
What kind of clock are you referring to here?
Re: HDSP 9632 clock
I mean the crystal oscilator which is on the card.
Re: HDSP 9632 clock
Changing the frequency of the card's oscillator will - obviously and logically - change all sample rates, means detune the whole card.
Re: HDSP 9632 clock
Ok, thank you for your answer. I'll try to find a 25 MHz oscillator.
Best Regards
staki
