Re: Mac OS X Test driver 2.65 for FF 400/800
you mean version 2.65 ?
thats an old driver, latest is 2.66.
i guess you did a fresh install of the driver and now you experience the "lucky first time".
please report if it still works after a reboot.
it is announced as 2.65 but the folder that I've downloaded under the link and the fireface setting/about says it is 2.67
and it works like a charm, I just did a reboot to verify it. And yes, I did a clean install- I removed the old driver and the related files as described by rme before.
hth
edit: it is just about the issue that when the mac is running and I switch on the FF the mac hangs and I had to make a reboot. This behaviour is remedied (for me) with the new driver. I do not other things like trying to change drivers while running Logic and so forth...
