Topic: New Fireface owner. Questions regarding samples and latency
Just bought a new Fireface 400 and have started to use it over this past weekend and just had a few questions. The card was set by default to use 256 samples which gives me good latency however I'm just wondering what the advantage is to using fewer samples, say 64 samples, other than even lower latency. What exactly are the benefits the lower you get with latency? Does latency only affect the timing and delay of things and nothing more, like quality for example? I notice the lower samples I set, the more taxing on the CPU so 256 seems to be about right and I can work comfortably here however the lower sample options just got me curious. Thanks all!!
