Topic: ground loop problem with PCIe AES
Are people still getting ground loop problem with this card, I thought it is ground-free transformer coupled! If there is no ground where would you get a ground loop?
RME User Forum → HDSP(e) series → ground loop problem with PCIe AES
Where did you read about ground loop problems with this card?
Someone just told me that ground free does not mean there is no ground, so I can still get ground loop problem.
Obviously there must be ground, otherwise no unit would pass any EMI, EMV, CE and whatever test. But the AES connection is ground-free as per the spec, using transformers.
So where is the ground? Is ground connected at pin 1 to the chassis in the card?
