Topic: Slave Fireface 800 crackling and making distorded noise.
I have to FF800 linked by ADAT 1 and WC. All settings are correct in sample rate and the two units have the same drivers and updates (sorry I don't have which driver version but I installed them this winter downloaded from the RME site)
My computer is a MacPro with 4 Gb RAM and Quadra 2.25 processors.
I run Cubase 4 with the latest upgrades and updates.
I had my units for 3,5 years and they been working perfect til' now.
I'm having this strange problem that occurs after 20 minutes of use.
The second unit gives out crackling sounds and sometimes distorded noise. At the same time I see that the  WC and ADAT LED's are flashing, so it seems like they are losing the connection and that what makes the crackling sound. When I look at the mixer the sounds appears on channel 13-20 (2nd unit). The first unit is silent.
The problem is coming during record, playback and even if I just start them up. And always after approx 20 minutes.
At first I thought it might be overheating so I spread the units apart in my rack, 1 unit in between, but it didn't help at all.
Have anyone else heard of this problem or in best case know what parameters might fix it?
I'm very grateful for help I can get. If you need to have more information regarding set up and other stuff I am glad to provide it.
magnus
Re: Slave Fireface 800 crackling and making distorded noise.
Please provide the settings for each unit for Clock Mode and Pref Sync Ref.
Here are the settings.
Master Unit
Clock Mode - Master
Auto Sync Ref - Input ADAT1, Freq 48 kHz
Pref sync Ref
Word Clock  - No Lock
ADAT 1 - Sync
ADAT 2 - No Lock
Spdif - No Lock
TCO  - No Lock
Slave Unit
Clock Mode - Slave
Auto Sync Ref - Input Word, Freq 48 kHz
Pref sync Ref
Word Clock - Sync
ADAT1 - Sync
ADAT 2- No Lock
Spdif - No lock
Tco - No Lock
Thank you again.
Settings are fine, it could be a hardware issue. If you just connect the unit that is having problems to the computer alone, does it cause problems? If so, you should send it for service. Possibly the power supply is starting to go.
