Topic: 9632 Issue Adat master
Hi all .New owner of a 9632
I am contemplative of the syncCheck ,Sync in ADAT,it's commute between Sync/lock Sync/Lock
is that what it's supose to do.?
ore is something wrong.
il be happy fore some help.
Regards/Hemmpe
RME User Forum → HDSP(e) series → 9632 Issue Adat master
Regards/Hemmpe
What is connected to the ADAT input and how is the sync configuration?
I have a Focusrite saffire pro 40 as Slave.
i have set the focusrite to adat out in to Rme ,then Spdif out to focusrite and it works well .
But i am curius abought the sync.Shud it be locked ore in sync?? if i turn on the auto sync it stays att sync.
and it works well to.
i am a bit confused.
I know you dont have a clue aboguth the focusrite.
But maby the synk in the master behavior?
regards Hemmpe
Seems ok - "Sync" is good...
