Topic: Fireface 400 drops connection right after switching on the mic
I have the Fireface 400 Firewire.. Used without problems for years now... But recently I'm seeing that it drops audio and red light appears right when I switch on the microphone (Rode K2).
The procedure is simple. The cable is connected to Input 1, microphone OFF, Input level around 30. Then I switch ON the microphone and Fireface stops responding. I have to unplug the firewire and and plug it again and then it works and I can record with the mic. But it's annoying and I don't know if I can damage the fireface or the mic.
I need some advice. Thanks
