Topic: Adi 8 QS Madi Digital Output
Hi All,
We recently bought 3 Adi 8 QS converters and a HDPSe Madi card for our studio in London.
I'm having some issues with getting them working with our Lavry Converter.
Our current setup is a simple loop using Madi Optic cable (PC > ADI 8 QS 1 > ADI 8 QS 2 > ADI 8 QS 3 > PC)
We have a dsub cable connected to the final converter, which is sending a digital signal via aes/ebu to our Lavry. I can tell a connection has been established because the Lavry registers bit rate changes I make on the RME's.
What I can't work out is why the Lavry wont output any audio? We are connected to the appropriate digital output, and we can see movement on the remote meter to indicate a signal is reaching the RME (we can also hear play back if we plug into the analog outputs of the RME) It seems that there maybe a setting we need to enable on our ADI 8-s to set them to output on their digital outs as well as the analogs?
Any ideas? is it even possible to convert Madi to AES/EBU using the ADI8-QS's?
Cheers,
Toby
