1 (edited by ffucOwner 2010-11-17 01:37:44)
Topic: ASIO Direct Monitoring works in Sonar?
I don't understand how I can benefit from the procedure described in the manual, where one "moves a fader in the the ASIO Host and the corresponding fader in Total Mix moves too".
I am using:
- Fireface UC with latest Flash (112) and latest TotalMix FX driver (0.961);
- Cakewalk Sonar version 8.3.1 (not the latest though - the one before)
I moved a Mains Fader in Sonar's Console (the fader labelled by Sonar exactly as in the drivers' page: "ASIO Fireface USB Analog 3(1)" ) and expected that the same fader in the "Software Playback" Row of TotalMix FX would move - as it is exactly the same stream/chanell as in the Sonar's Console - but it does NOT move.
Any help/explanations?
Thanks.
- Core 2 Quad Q8200 @ 2,33 GHz;
- MB Asus P5B-E;
- Windows 7 Professional x64;
- Sonar X1 x64.
Re: ASIO Direct Monitoring works in Sonar?
As far as I am aware, Sonar 8 does not include support for ASIO direct monitoring.
