Topic: Strange beeps on micstasy preamps
I have strange problems with micstasy. In certain scenarios, there are strange beeps present on all 8 channels.
There are constant beeps repeating on every second or so.
Here are some observations:
- beeps appear while the microphone with its own power supply is connected to micstasy. Phantom power on micstasy is turned off.
- beeps also appear, while any other condenser mic is connected, but the phantom power is not yet turned on. When I turn the phantom power on,
the beeps go away
- if dynamic microphones are connected, there are no beeps.
- the gain must be set to at least around 40db to hear the beeps.
- If I push the select knob, while the beeps are present, the noise from blinking display appears in signal. It goes away, when display
on channels stops blinking.
- if there is nothing connected to inputs, the beeps are not present.
I have recorded this strange beeps, but I don't have the file on this computer. I can upload it on a server tomorrow.
Micstasy has the latest firmware and is connected via analog outputs. I don't use digital connections.
