Topic: Totalmix FX CPU load increases when Midi is enabled
Maybe a small issue, maybe a normal behaviour, but I noticed that CPU load for Totalmix FX slightly increases (up to 4 % on my machine) when Midi is enabled and Totalmix window is open or minimized. When I close the the window or disable Midi the CPU load is 0 %.
Fireface UFX (via USB), 110/0.964
Intel Core i7-860
Windows 7 (64 bit)
Re: Totalmix FX CPU load increases when Midi is enabled
I don't see such a behavior. The CPU load only goes up when MIDI data are sent, means faders are moved. But then it also goes up without MIDI. The difference MIDI/no MIDI is about 2%. TM FX just sitting there and showing levels stays below 0.5% either way.
