Topic: Mixing ADI-8 QS and older ADI-8 devices
can somebody tell me if the latencies of the new ADI-8 QS and the older ADI-8 DS are comparable?
Andreas Neubronner
Tritonus Musikproduktion GmbH, Stuttgart (Germany)
www.tritonus.de
RME User Forum → MADI/AES Premium Line → Mixing ADI-8 QS and older ADI-8 devices
Andreas Neubronner
" In the QS RME uses a high-class AD converter from Cirrus Logic, offering exceptional Signal to Noise and distortion figures. But the biggest difference to all other ADCs out there is its innovative digital filter, achieving for the first time a delay of only 12 samples in Single Speed (0.25 ms), 9 samples in Double Speed (0.09 ms), and 5 (!) samples in Quad Speed (0.026 ms).
These values are less than a quarter of those available from even much more expensive devices. They represent an important step in further reducing the latency in the computer-based recording studio. At DS and QS the added latency can simply be ignored. The DA-converter offers similar conversion in the range of 5 to 10 samples, turning analog digital monitoring into real analog-style monitoring!"
(http://www.rme-audio.de/en_products_adi_8_qs.php)
Und, wat sacht mi das nu?
translated into Oxford English:
And, what's the quintesence of it?
And, what's the quintessence of it?
That the QS' conversion latencies are considerably shorter than those of the DS and other comparable converters. About a quarter or so...
ADI-8 DS: AD 39 samples, DA: 43 samples
That's what I wanted to know.
Thanks a lot, Herr Carstens!
(?brigens, ein wunderbarer Konverter !!)
Und jetzt warten wir auf die richtige Antwort auf die unvermeidbare Frage: welcher von beiden?
:-);):cool:
Ich finde sie eigentlich beide gut. Aber der QS ist nat?rlich extraklasse!
Und der Kandidat hat hundert Punkte! Den Gewinn bitte am Stand auf der n?chsten Musikmesse abholen.
Dear Herr Carstens,
you've sent the latencies of the ADI-8 DS. To compare I would need the latencies of the QS as well.
P.S.: Ist die Tonmeistertagung auch m?glich, um die 100 Punkte abzuholen?
Das gibt jetzt aber Punktabzug... ![]()
Die hab ich doch oben schon angegeben, in dem Zitat von der Webseite...
Nochmal auf Deutsch? Hier entlang...
mfg
Schlimmer noch: gelistet als Tabelle im QS-Handbuch. Gewinn leider verspielt...
Zitat aus "Zar und Zimmermann":
"Ja, das Rechnen und das Lesen, ist noch nie mein Fach gewesen! Schon von Kindesbeinen, besch?ft'gt ich mich mit Schweinen."
Sorry und Danke
...na hoffentlich k?nnen die singen.:-)
regards
Zapp
