Topic: HDSP9652 Driver V3.083
Hi
I currently run 2 HDSP9652's on a Pc using Driver V3.082 without any issues. Are there any fixes/improvements  in V3.083 that would justify me installing it.
thanks in advance
Mike
Re: HDSP9652 Driver V3.083
Don't try to fix what aint broken...
AKAIK the latest driver available is 3.085
Update 3.085, 08/05/2010
- MADIface: Quad Speed did not work in slave mode
- HDSP 9632: Firmware 152 was missing in the driver, so the card was not detected
Update 3.084, 07/08/2010
- TCO: timecode offset changed for Magix software
- TotalMix: The tooltips on the preset buttons did not work
- HDSPe AIO: The WDM loudspeaker device can now be used for 6/8-channel playback
Update 3.083, 02/19/2010
- HDSP MADI Settings dialog: TCO removed
- About Dialog: Vista MMCSS option removed
- WDM: SPDIF AC-3 is only supported on SPDIF devices
- WDM: MADIface had no Loudspeaker device
- WDM: Analog DVD multi-channel playback via Loudspeaker device (change loudspeaker configuration to 5.1 or 7.1)
- ADAT Sync (HDSP9652, Multiface, Digiface): APP did not work correctly since Cubendo 4
Update 3.082, 10/20/2009
- Support for Flash Tool 2.19
My Mistake
I am running V3.084 and was  wondering whether to install V3.085(Latest.)
