Topic: Newby to S/MUX-some questions before I get going
I'm getting ready to wire in a fairly involved hardware configuration. I need to be able to switch sample rates between projects while not having to physicaly repatch any gear. I'll be using a MADI PCI/ADI 648. When changing from a 44.1 KHz projects to a 88.2 KHz projects do the HDSP MADI/ADI 648 channels reconfigure as follows??:
ADI 648 ADAT I/O 1
channels 1 & 2 combine to create channel 1
channels 3 & 4 combine to create channel 2
channels 5 & 6 combine to create channel 3
channels 7 & 8 combine to create channel 4
ADI 648 ADAT 1/O 2
channels 9 & 10 combine to create channel 5
channels 11 & 12 combine to create channel 6
channels 13 & 14 combine to create channel 7
channels 15 & 16 combine to create channel 8
or is it.....
ADI 648 ADAT I/O 1
channels 1 & 3 combine to create channel 1
channels 2 & 4 combine to create channel 2
channels 5 & 7 combine to create channel 3
channels 6 & 8 combine to create channel 4
ADI 648 ADAT 1/O 2
channels 9 & 11 combine to create channel 5
channels 10 & 12 combine to create channel 6
channels 13 & 15 combine to create channel 7
channels 14 & 16 combine to create channel 8
or is it
ADI 648 ADAT I/O channels 1 & 2 combine with ADI 648 ADAT I/O 9 & 10 to create channel 1 & 2
ADI 648 ADAT I/O channels 3 & 4 combine with ADI 648/ADAT I/O 11 & 12 to create channel 3 & 4
ADI 648 ADAT I/O channels 5 & 6 combine with ADI 648 ADAT I/O 13 & 14 to create channel 5 & 6
ADI 648 ADAT I/O channels 7 & 8 combine with ADI 648 ADAT I/O 15 & 16 to create channel 7 & 8
I just need to know ahead of time before I jump into this. I'm going to be having to do this install without any assistance and I don't want to spend a whole day getting this wired in and then end up with a total cluster**** in my signal routing.
Is there a .pdf on this somewhere on RME's website?
Many thanks in advance.
