Topic: Routing MIC Input 1 to Analog Out 5 inside the TotalMix
Hi there
I would like to route the MIC 1 input to the analog output 5 in order to send the Mic signal out of the fireface to process it with an external FX device.
The setup of my totalmix looks like this:
http://www.nicogrubert.ch/FF400_Settings.jpg
Unfortunately I dont get any signal on OUT 5. Any ideas what I did wrong?
Nico
Re: Routing MIC Input 1 to Analog Out 5 inside the TotalMix
http://img193.imageshack.us/img193/3782/ff400settings.jpg
thanks a lot. got it to work. :-)
great support !
You use it the complicated way. Activate the Submix View. Now click on output 5 (NOT the channel label) in the lowest row so it gets highlighted, then pull up any fader you want to have on that output (here input 1). Never deselect Submix View within the first year ;-)
http://www.rme-audio.de/forum/viewtopic.php?id=5039
