Topic: HDSPe AIO MADI
Hello
We have en MAC PRO 2008 with a HDSPe card and a AIO card.
We have connectet HDSPe card and a AIO card with a wire inside the MAC to sync.
We have 2 Micstasy where we use MADI (Opitical) to connect with the HDSPe.
Talkback and playback
We use talkback from a mike (in Mackie Big Knob) connectet to audio in on the AIO card.
We use to route the input from AOI (Through Logic Pro 8 with a Audio in fader with a BUS out to a AUX with output 7-8) to ADAT out on the Micstasy to a Behringer PRO 8 Digital ch. 7/8 to a Headphoneamp. And it works also when we route the playback through. But sometimes it go out of sync?
HDSPe settings
In the HDSPe settings the HDSPe is master and the AIO is slave. "Pref sync Ref" is set to MADI on the HDSPe.
Another way?
I have seen one of the video (on YouTube) where the HDSPe is used to talkback and playback.
If we want to use HDSPe mixer as talkback and playback with the same in and out (maybe not out through ADAT but out on the Micstasy?),
can we then route the audio signal on the AIO in to on the HDSPe out so we can use it to talkback and playback?
With regards
Flemming Poul Giese
