Topic: Matrix doesnt update as totalmix changed
Hello to all RME friends,
I am loving and learning about Totalmix.
I have both Totalmix and Matrix open at the same time.
When I change a Totalmix fader in the playback row ( second row ) I can see the equivalent value in the Matrix change to show the same value as in Totalmix.
However, when I change a Totalmix input fader level (first row), the equivalent value in the matrix does not change. To see this change requires that the matrix is closed and then re-opened. Now the value will have been updated.
Is this normal behavior please?
Kind Wishes
Jim
Re: Matrix doesnt update as totalmix changed
is your FF driver up to date?
Hello Daniel,
Thank you very much for your reply.
I have a MAC Pro quad core and Snow Leopard 10.6.2
Two FF800 both have firmware 2.77 and driver 2.89
I noticed this same issue in earlier driver versions of the FF800 where the matrix fails to update input fader changes (first row Totalmix fader changes) until it has been closed and then opened again.
I look forward to your response.
Kind Regards
Jim
