Topic: Adat and madi in use at the same time 48k and or 96k
Hi im have a bit of trouble seting up my system im a bit new to the Rme units. I have a M-32DA and a M-32AD units with the HSpe 128 card. I have no trouble running it using Madi fiber as the hookup from the computer card to the 2 units 64ch at 96k or 128 ch at 48K works great.
My question: I have diffrent outboard gear Iee: a mixer Yamaha used as a monitor mix and some efx units lexicons 300, Fireworx etc all having adat connections I would like to connect this via the adat on the RME Units and use the Madi from the HSPE card to get In and out of the M-32DA and the M-32AD used as track recording and monitoring for the studio speakers etc. I understand that i will loose the some of the M-32 analog ins and out propornal in that I am limited to the unmber of Ch depending on the KHZ used. But i can figure out how to send out threw the adat fiber or input threw adat fiber at the same time as inputing and outputing on the units threw the m-32's analog ins and outs. Can this even be done, can I just lock the two M32s via the madi sync from the hspe card then use the adat lock on the adat line or do i have to lock the whole sysem to the word clock. I cant even find how to asign the outputs to the adat outs i have not trouble with sending to the M-32 in and outs. But i see nothing that says heres the adat out in any of the controller conection windows. THere is a list of 64 amdi ins and 64 madi Ins and outs at 96k or 128 madi ins and outs at 48k. Thanks for any help. feral
