Topic: No speaker sound
I just received and installed my new Fireface 800.  Sound comes out of the speakers fine when using Cubase but I can't figure out how to get sound when running other programs such as Audacity or games.  Sound comes through the headphone jack on the Fireface, and when I click on the speaker icon in the tray it shows a signal is present, but still no sound in the speakers.
Re: No speaker sound
Check your System Pref / Control Panel settings to see which channels are selected for default sound output.
I went there and chose ADAT 1 (1 + 2) as the default setting.  There is a green check mark by it, showing it as the default.  It was the only one with the meter showing a signal present.  Still no sound coming from the speakers.
You will have to change the default to the channels your speakers are connected to, or else re-route the audio with the FF Mixer.
I'm sorry but I'm not sure what you mean.  Cubase sound comes out of the same speakers (routed through an amp and the Fireface) that all the rest of my computer sounds come through.  With my old audio interface (Focusrite 6 usb), I had the same setup and all the sounds-Cubase as well as Audacity, games, etc. would all come out of the speakers fine.  Now only Cubase does.
If you already understood this to be the case, my apologies.
I tried choosing every possibility in the sound area of control panel to be the default, none of them work.  Only one of them shows a signal on its meter but it doesn't work either.  So perhaps I need to re-route the audio through the mixer as you suggested.  I'm a complete noob with the mixer--can you give me any suggestions as to how to do that?
Do you have your speakers directly connected to the analog 1/2 outputs of the FF? Then choose "Speakers (Fireface 800)" in control panel as default.
Or, see here for beginner help with the Fireface mixer.
http://www.youtube.com/watch?v=splW9OtTBYw
Okay thank you for your help.
I will be returning this unit today.  Still can get no sound from my speakers, except for Cubase.  Wasting too much time on what should be a very simple problem to solve.
http://www.rme-audio.de/forum/viewtopic.php?id=1018
Also try this beta driver: http://www.rme-audio.de/forum/viewtopic.php?id=10508
Do you see any levels in the mixer at all when playing back with other software? Have you got Cubase open as well?
