Topic: Fire Face 400 Waves rack
I bought a new fireface 400. wired it connected it download drivers, installed them. I see audio is comming on the mixing tool, lights in the input signal from channel 1. Nothing coming thru to waves. There is a processor overload on 4%. even when there is nothing inserted. Last week i tried this with a maudio device.. No problem at all.. It seems that the rme mixing tool and waves have a routing argue..???
  Modelnaam:    MacBook Pro
  Modelaanduiding:    MacBookPro5,1
  Processornaam:    Intel Core 2 Duo
  Processorsnelheid:    2,53 GHz
  Aantal processors:    1
  Totaal aantal cores:    2
  L2-cache:    6 MB
  Geheugen:    4 GB
  Bussnelheid:    1,07 GHz
Does anyone know this problem..?
Re: Fire Face 400 Waves rack
After some research i find out that my computer lose the fireface connection after i start a third party application. The red light starts to burn when I start Garageband or Waves Multirack... Everything.. I tried every firmware and driver combination but it wont work..
Pls help me :-(
I'm starting to think that i should return it..
Not a Fireface problem:
http://www.rme-audio.de/forum/viewtopic.php?id=1475
http://www.rme-audio.de/forum/viewtopic.php?id=974
Thnx for you're reply. The work around worked for me. So it is apparently my laptop... Sad but true.. Unfortunately this is to much hassle for flight-shows all over the world so i ordered the USB version. Hopefully this will solve the problem.
