1 (edited by neobnu 2011-04-08 02:16:57)
Topic: Problems with FF 800 - no recognized
>> Product: RME Fireface 800
>>> Manufacturer: RME
>>> Model: Fireface 800
>>> Date of purchase: more or less for 3 years
>>> Place of purchase: Showpoint (Brazil-RJ)
>>> Hardware Description:
>>> Operating system: Windows 7 Ultimate (Original) 64bit
>>> Motherboard: Maximus Formula startling
>>> Processor: Intel Q6600
>>> RAM: 2x2GB Corsair Dominator 1066MHZ Married
>>> Video Card: Nvidia G-Force Series 7
>>> Audio Software: Adobe Audition 3.0.1 (Original)
the tests
I tested the port 400 on 3 different computers not recognized
I tested the port 800 on 2 different computers and did not recognize
ff800 reinstalled various drivers and FireWire card and the pc did not recognize
Hello, this my equipment worked perfectly for 3 years
Then one day I got a BSOD (Blue Screen, Fireface_64.dll) then
after restarting the machine it no longer recognizes the manager
Slide HOST and the red light stays on, I used the
cable that accompanied the original product, she connected the FireWire 400 port of
unit. , After an extensive search in the forum of RME, soon identified
many people with the same problem, SOURCE>
http://www.rme-audio.de/forum/viewtopic.php?id=9979
http://www.rme-audio.de/forum/viewtopic.php?id=5515
http://www.rme-audio.de/forum/viewtopic.php?id=10712
http://www.rme-audio.de/forum/viewtopic.php?id=10458
http://www.rme-audio.de/forum/viewtopic.php?id=10355
even there also reported that some people will
in Brazil with the same problem that even in the same store bought that I,
after contacting technical support as the official site of RME
that my parents would
BRAZIL
Um Instrumentos e Equipamentos Ltda.
# Rua Godofredo Rangel,
# 80 - SP
# Brasil - 04.051-010
# Phone: (11) 5581-8881
# Fax: (11) 5581-8881
# E-mail: vendas@uminstrumentos.com.br
# Web: www.uminstrumentos.com.br
One called for Um Instrumentos and asked me to contact the support department that might be.
Show fix
atendimento@showfix.com.br
Contact: ES (28) 3554-2389
Then after talking to the coach by phone and explain to him what happened, he told me he has several cases
like just sitting there including some that are still under warranty, he said that the problem would be the FireWire controller card
and that the supposed IC (or IC) that this would "CI TSB81BA3" was not coming and the request had been made Presonus a lot of time so
there was no prediction of how long the concert.
I like the trademark user RME I felt compelled to come to the forum to try and help get a certain satisfaction about this, because my
studio is completely stopped because of this inconvenience I have no idea what happened or why the coach knew me explain it
why it came to pass this problem, much less found in the forum details, just things like "you fried your input" but no one talking or
explaining why this happened, I think the RME is a serious company-level and extremely professional and love working with this interface, but
not understand how the RME FF800 and the "Sound On Sound" Best Computer Audio Interface "Award 2011" could no longer work with a simple restart the computer,
and need to know exactly what is causing this problem so i rather have a chance to avoid him, I understand problems happen ... but the biggest problem now is no prediction
spare parts to service, it is somewhat disrespectful to the customer, even in my case where appointments were in the studio that depended on the board.
With all due respect.
We as customers rme an explanation about this problem.
Some doubts.
How should I proceed?
This CI should not be provided by the RME for the replacement parts had to be original? who does this fall and the PreSonus or RME?
Who is responsible for replacement parts for the technical assistance of RME?
Doubt is the most important because this is happening with me and so many people, leading to what this port will burn?
Can I get this IC on my own and it will send technical assistance to repair, if so where do I find?
I am very grateful for the help.
Diego D.
Re: Problems with FF 800 - no recognized
sorry for the trouble, but even 100 awards can not prevent an occasional hardware failure... The cases you quote are not necessarily related. I also don't quite see why you (or Um Instrumentos) mentioned Presonus here...
There is no simple explanation for what happened in your case. To be sure, the unit would need to be examined at the factory. I am not sure just exchanging a chip will be sufficient.
Hello Sir Daniel, thanks for the help.
where is this factory that makes you say?
how to proceed?
what did you think that only the chip is not resolved?
PRESONUS about since you have doubts about I explain without problems, I
also like to understand after all ...
  what happened was that the authorized dealer from Brazil told me that probably burned the FireWire controller IC and if this was really good would not the problem because I have had some cards there waiting for this concert, there was only one IC and said who supplied this CI was Presonus but the request has already done this long ago and do not reach the CI,
I really do not understand what the PreSonus has to do with the components of the RME.
can you explain? I would understand.
help?
tanks
That should be Germany.
how to proceed?
Have the defective unit sent in to check the damage.
Until someone takes a look at the damage no one can say if only a chip is broken or maybe more.
Who told you that the broken part (IC) had to be ordered from PreSonus?
Hello Timur
thanks for support
who told me of the IC was the "Show Fix (ES).
I'm going to personally behind this IC, was thinking of sending him along with the board to ShowFix to expedite the process.
could you tell me if this workshop is authorized?
what would be the best option?
Thanks Timur.
