Topic: ADI-2 Spidf output failure
I have recently purchased an ADI-2 (firmware 1.4) but I am unable to successfully connect the A/D coaxial spdif output to any interface. The analogue inputs and outputs are functioning. The D/A coaxial spdif input is also working and will lock to external spidf clock.
I have tried to connect to M-Audio, Benchmark and Apogee hardware, but none of them identify any spidf signal from the ADI-2. I have used different 75ohm cables and have tried all output switch options.
I have not tested any of the optical ports.
Is there an internal jumper setting that may be to blame, or does this sound like a defective unit?
Cheers...
Adam Dowling
