Topic: HDSPe MADI clock malfunction
Hey all,
I just installed a HDSPe Madi card (Rev. 1.1) into a Intel MacPro.
As usual I upgraded to latest firmware and driver right away.
I am operating the RME-Madi as sync-master.
Connected to the Madi-cable I have a J?nger-Audio Madi-card, which
itself is technically working as it should, but is not able to sync
itself to the Madi signal correctly. Trying to use the Wordclock output
it shows the same behavior.
Therefore I measured the clock of wordclock output at different sample rates.
For 44.1 and 48 kHz it was about 150 Hz different and for 96 kHz about 300 Hz.
So, my question: is there a known malfunction of the oscillator on this HDSPe
Madi boards.
Best regards,
J?rg.
