Topic: Fireface 800 install problem on new W7-64 machine..
Hi guys,
I just tried moving my FF800 to a new W7-64 machine. I installed the latest drivers. I followed the driver installation procedure, and it seemed to go without a hitch.
When I tried accessing the Fireface Settings dialog (system tray), it immediately told me that that the older firmware that I was running was too old for the current driver version...
So I launched the firmware update tool and it seemed to update fine... it asks to turn off and then turn on FF800. Did that and after it powered up I tried to go back to the Fireface Settings - nothing happens. (ie: the window does not open or any other reaction.) Same result when I try to open the Fireface Mixer.
I go to the Device Manager and the FF800 is not there... so I restart my computer... still nothing and same behavior for Mixer/Settings windows. Power cycling or unplugging replugging does nothing ...it's as if the machine no longer sees the FF800 - and device manager seems to reflect that. (Rescanning there does nothing.)
Ideas? Getting desperate here...
Cheers!
Rob
Poretti Productions
(I am *not* an ADAT user.)
