Topic: Cue function in TotalMixFX
Hi there.
I like the CUE function of the Hardware outputs in TotalMixFx; but: I urgently need this function to be routed to the PHONE1 output, too, not only to the main output. During my recording sessions, the hardware outputs are used as individual stereo monitoring (headphone-) mixes for the musicians. As a recording engineer, I need to listen to the headphone mixes of the musicians to check the signal, sometimes (using a headphone, too). It would be great if I could do this by the CUE function.
What do you think about this?
Thanks,
Johannes
Re: Cue function in TotalMixFX
Use the "Assign" button to set the Phone output you use (9/10 or 11/12) as "Main". The Cue button sends the submix to whatever is selected as "Main".
Yes, I've tried this. This is working. Would just be more comfortable if I could leave the routing in basic configuration (main to speaker). But you are right. Just two clicks more. Anyway, if your software engineers have some bits left... ask them about it.
Johannes
