Topic: No ADAT Signal from MR816
Hi Folks,
I finally got my 9652 installed and seem to be having a problem getting ADAT signal to and from my Steinberg MR816. When I plug a mic into one of the MR's inputs I show no meters in Total Mix. I have a Behringer AD8000 also hooked up and get ADAT in and out with no problem. If I plug a Mic into one of the AD8000 inputs I get signal and the meters move when I tap on the mic.
I have the MR816 connected to ADAT3 and set to get it's clock from ADAT and Sync Check shows a steady Sync on the ADAT3 in. I'm stumped.
Re: No ADAT Signal from MR816
The MR816 digital outputs don't work in all of its modes. Better ask at the steinberg forum (or read the manual).
Thanks vinark, I think I got it sorted out. I didn't know that I had to go into the MR editor and bring the channel levels up for each of the pair of ADATs. They have them grouped in pairs. As far as I can tell this isn't mentioned in the manual.
