Topic: New USB series Windows driver - public beta - update 3
the next USB driver coming up includes some significant changes. After a lot of internal testing it is now ready for public beta testing. As usual do not use this one on a production system and with sensitive data. If you need to make money with our hardware - don't fool around, use what works, stay safe!
Its most spectacular feature is the addition of multi-client mixing. You can now use any number of programs of any sort (WDM, ASIO) to play back on the same channels. Note that as long as you use only one program per playback channel the driver works as before, including bit-perfect playback.
- Correct installation of the Settings dialog under Win 64 (solves crash when called from Cubase)
- New TotalMix FX 0.93
- TotalMix FX help correctly installed under Win 64
- Settings dialog saves the current position
- Settings dialog: Pitch menu/list box improved
- Settings dialog: sample rate list box improved
- Settings dialog UC: partly wrong status information fixed
- WDM UFX: ADAT 1 1/2 is no longer labelled SPDIF
- Various small improvements of the WDM driver
- Multi-client playback mixing on identical channels
Happy testing!
!!!!!Update 04/15/2011 !!!!
- WDM: playback with buffer size 512 or higher had clicks and drop outs
!!!!!Update 06/15/2011 !!!!
General:
- Settings dialog: TMS had been switched off on every restart
- Settings dialog: In some situations a tab for non-existing devices was shown
- New TotalMix FX 0.94
Babyface:
- Bug fix high interrupt load when removing the driver under W7 SP1
There are also new firmwares available for Babyface (184) and UC (115):
!!!!!Update 06/17/2011 !!!!
Links removed as all drivers and firmware have been released on our website.
