Topic: FF800 version 2.3 last updated in 2005
Hi,I bought my FF800 new in 2005,thinking I would build a studio.But too many things got in my way(Murphy's Law!) Now I have the time and place to do it...My question is what version driver do I need to install for it running Win XP?I can give you the serial# if you need it.Thanks alot for your time...Sincerely,Dustin
Re: FF800 version 2.3 last updated in 2005
The current driver & firmware is still compatible with XP.
http://www.rme-audio.de/drivers_fireface
See here for instructions: http://www.rme-audio.de/forum/viewtopic.php?id=732
Thanks Jeff for responding back with your answer and links.I will be using Reason 5 and Record 1.5 with midi sometimes.What version should I use to give me the best results...OK Stupid Question:Do I need to download and flash each progressive version from 2.3. or just the version that you might suggest?...Thanks again for your time.I Know you are very busy and I promise to not bother you anymore! Much Appreciated,Dustin
No. Just install v3.047, then update firmware to v2.77. Easy smile
Great...thanks Jeff!!!
