Topic: Minimum Buffersize: What has an influence
Dear Community,
I have two PCs operating Windows 7 64 Bit. Both are multicore CPUs with the Hammerfall DSP Multiface II installed
involving the same driver version (3.08.5).
I tried to find out the minimum latency achievable for both systems. On system I, I reached down to 32 samples without
any problems. On system II, a buffersize of 64 samples does lead to a completely distorted signal, the minimum size is 128.
Completely distorted means that every buffer seems to be corrupt, not just a single dropout or so. Testing the bad system
with dpclat shows no problem.
What can be the reason for this bad behavior?
Thank you in advance.
Best regards,
Hauke
