Topic: ufx mic input 9 to 12 as line in
i would like to use my neve preamps instead of the ufx mic pres (the back 8 line in's are all used up).  the question is:  do the xlr inputs bypass ufx pres?
thanks!
Re: ufx mic input 9 to 12 as line in
No.
You might find some interesting information in this thread:
http://www.rme-audio.de/forum/viewtopic.php?id=10912
RME Fireface UFX
Mac Mini 2.6 GHz 16 GB Ram Areca RAID | MacBook Pro 2,2 GHz 16 GB Ram | OS 10.10.5
The UFX preamps are designed to be absolutely neutral. Even with the highest gain settings. A gain value of 0 dB don't affect the sound in any way so a real hardware bypass makes no sense. If something is different to the inputs on the rear it is not the digital preamps but the Advanced Parallel Conversion of the four front inputs.
best regards
Knut
thank you both for the info.  looking at the link eric provided,  a pad seems to be the answer.
cheers!
