Topic: DIGICheck: "Device Opening Error" after latest driver updates
Hey there,
Iam working with a Hdspe Aio on my Windows PC and updated the latest flash-update and wdm streaming driver. That fixed an issue with my headphones, so the card works fine now.
Digicheck (5.32) now has an "Device Opening Error". When I go to the "Input Device Setup" (F3) "ASIO Hammerfall DSP" is selected (like before the update), but that doesnt fix the problem after i select it again and confirm that.
Need some help here!
Michael
Re: DIGICheck: "Device Opening Error" after latest driver updates
I just had the same error, but for me the "Input Device Setup" was empty. When I selected the device it worked. Make sure to check the channel settings, too, the default seems to use Analog 1 for both channel 1(l) and 2(r).
No, the channel settings are correct. I tried other combinations too, but didnt work either. (yes analog, phones, AES, ADAT etc. are listed)
Please give us the exact driver version that you are using.
-flash update tool from 04.08.2011; .exe says data file version 2.2.3.0
-wdm streaming driver 3.26
downloaded from here: http://www.rme-audio.de/en_downloads.ph … iver_hdspe
-digicheck 5.32
installed in the same order.
Please check if ASIO works at all. If it works with other software it should work with DC as well.
